Keyur Kanade
Sharetopo may fail if there are geometry errors. Please check geometry in SpaceClaim. Select geometry in structure tree --> Use right click --> Select Check Geometry. The geometry should be error free to proceed. If geometry has any errors, please modify/recreate geometry at those places.nTo make share topo successful, you may need to think of any geometry modification. Please check if you can use DesignModeler or SpaceClaim. Both has sharetopo. nn
" target="blank">
nnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
