January 7, 2021 at 9:11 am
Hi Array Yes, it is correct forum to post these queries.nYou can use command snippet to add initial condition using IC command. Please check the details in this help link. You need to insert the command under body by right click on body.nhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/ans_cmd/Hlp_C_IC.htmlnYou need to create a named selection for this body. For example if you create Named Selection Body_melt, you can make the command IC, Body_melt, temp, 1350. Please check the solver unit is same.n
