elwinxavier
Array appreciate the kind help. Unfortunately these doesn't help.nMy problem aren't really nmake. I'm using 2020 R2, I have the feature to enable Built-In Compilersn nSo the problem Statement is, when in Compiled UDFsnBuilt will result following Errorn'C:\PROGRA~1\ANSYS' is not recognized as an internal or external command, operable program or batch file.nLOAD will result following ErrornError: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).The system cannot find the file specified.nnnDo ANSYS staff knows, with Build-In Compiler, is the problem still lies within Visual Studio? Because if it doesn't we can certainly skip the MS Visual Studio and look other way.nOr the problem is more to the Build-in Compilers itself. Is there anyway to check on Build-In Compilers? DO we have any patch and installer to re-install on ANSYS Patch?n
