Ashish Khemka
nnWhat is the number of equilibrium iterations you are using? If you have not changed the same then can you try increasing the number of equilibrium iterations using the command in the Setup branch:nneqit,100 ! This increases the equlibrium iterationsnnRegards,nAshish Khemkan
