marky24
Helllo thank you for you answer.nThe test that I am simulating is the following:n
" target="blank">
nand it is performed with this assembly, where the load has a value of 1800N, for example, and rotates an angle w, dependent of time.nWhat I have done is:n1) Remote load in the whee of 1800N, where the shaft is assembled.n2)Fatigue tool with ratio of -1 and scale of 1nIs this correct?n
