Aniket
Hi!nI see that you have used references to two different versions. I just tested this in 2020R2, and using IntelliSense in the ACT console you get a fair bit of idea about the arguments to be used:nNow, the first way can be as ana.GetLoadObjects(ExtAPI.ExtensionManager.CurrentExtension) or as in the second way you can use a string of GUID or the extension name.nnI hope this helps!n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
