LeoMereles
nnThanks for your response.nnI already checked all the parameters. My results are exact like the Maxwell manual, but, I'm asking because the rated torque at the rated current is 400Nm at 250A.nnThe papers I checked are the same used inthe manual, you can check the 3 references here:nn So if, according to the User's Guide, the results are ok and with the same current I'm getting the same results that the guide, why differs from the real results? According to the guide, 243Nm is the result for 250 A. My result is a little more because of the advance angle change (50° for the optimum results).nnBest regards,nLeon
