HI @
LeoMerelesnCan you also add a screenshot of the reference page where it showed 400 Nm @ 1200 rpm or rated speed.nI did see the third reference document in the references and it says max torque of 400 NM from 0 to 1540 rpm. So 400 Nm is not at rated speed.n
The test result also says 400 NM for 250A current is for locked rotor condition and it is not for the rated condition.n
Hope this clarifies your concernnnRegards,nNavyan
