January 19, 2021 at 10:33 am
Hi, sir .nYes, I initially applied the bolt pretension in the first Structural Analysis model. nLater in the third SA model, I only took the adjustment value into it. nIn Parametric Table above, the column U is the value for the bolt pretension which is 10405 N.nThen in column X, you can see the value of the adjustment that I applied (1.3582e-4 mm).nnBelow I attached you the value of bolt preadjustment in the Steps mode. n
n
