January 19, 2021 at 12:57 pm
Ansys staff can not download any files on the learning forum, so if you want to reach a larger audience to get answers from, please insert the images inline.nAlso, thanks for taking efforts to use the journaling feature for your needs, You should be able to script these two options in the Mechanical using ACT automation APIs, but if you connect the systems as follows to your systems in Workbench, (As you are already aware these are recorded in the journal file).
nYou can generate the B4 cell when the APDL system is connected, and it should write the APDL input file (sys-1.dat) for the mesh in your model. n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
