nIt doesn't read the file because you have spaces in the folder names. Save the project and the text file to a path that has no spaces in the file name or folder names. nYou have a mistake on line 12, you are missing an _nReading the file is all the linking needed.nI recommend you prove out the concept on a file that has 100 rows of the data before you try to run the full load case.n
