swapnil13
Respected sir,n I am using fluent in series only but while compiling it gives error as 'The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64),The system cannot find the file specified.nFor that I had installed visual basic studio 2017, started ANSYS fluent from its command line but it is giving same error as above.nUdf as I had mentioned in video uploaded in your YouTube channel.I had not changed anything. Everything is as per given in video.nPlease help me nThank you,nSwapnilnn
