February 2, 2021 at 5:29 pm
Weird I expect if you edit in the parent setup cell these values and you save the values will be preserved. Can you recreate the case edit the values then add the parameters save project add two design points and run? There is for sure another way to enforce Fluent to recompute the values but please test what I have asked first.n
