Forum Moderator
You can:n
Occasionally people will send links to the Help system rather than give a reference. These trigger a password check on the Ansys system, but..... For anyone who is having the same problem as I have, i.e., not being able to access the URL (shows Customer Portal Login). You can access these links by:First open the help section of Ansys through the software ( ? button on the upper-right side of the Fluent Solver User Interface: This opens help in a browser)Copy the link you want to access Past it in browser URL (new tab) where the help documentation had been opened.You can access these links. Just in case this helps someone.Thanks to @smalbro93 for the hint.https://forum.ansys.com/discussion/22563/using-help-with-links
n
