February 3, 2021 at 6:05 pm
SOLID65 is an archived (no longer actively developed) feature so it's capabilities may be somewhat out of date. Documentation for SOLID65 is in the Feature Archive Manual.nFailure of a concrete element can occur due to either cracking or crushing. If too large a portion of the model has failed to satisfy equilibrium or possibly to make convergence possible then typically the solution will just stop with an unconverged solution. A solution strategy is to use many very small time steps and ncnv,0.nThere is no material model that can be specified for solid65 that includes degradation. If progressive damage needs to be included it is recommended to use solid185 with the microplane material model.nThe meaning of the PLCRACK plot is included with the PLCRACK command in the Feature Archive as indicated below:n
n
