February 4, 2021 at 4:38 am
For testing purpose, split the geometry in SpaceClaim. Take only small portion of geometry and try to mesh it. Change settings as required. Once you successfully mesh that small portion, you can use same settings for entire model. Please check if you can use different method as patch confirming tetra etc. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
