February 4, 2021 at 7:54 am
nWhat is the exact purpose of your analysis. Are you interested in the force results across the interface? Or do you want to see results across the whole cross section? In case of the latter one you could simply merge both plates, created a single sheet and model it as either by 2d or 3d elements. If you are interested in the interface, create a bonded contact model using 3d elements and view results using contact tool.nRegards,nIshan.n
