Erik Kostson
The object generator could potentially be used for that .nSo one can put the beams in a named selection, the vertices in another named selection, then create one end release, and finally use the object generator to create all of them in one go (using the first created end release and the named selections).nThis could be a possible way perhaps , so you would need to try and see if it could work.nn
