Rahul Kumbhar
APDL cant read two db file but it can read cdb file. You can export one db file as cdb file. Resume another db file and then import the cdb file in it. You might need to use NUMOFF that goes along with the CDWRITE command to offset the element,node numbers. Please check the Ansys help for more details of the commandsnhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/ans_cmd/Hlp_C_CmdTOC.htmlnThe another way is you can export both cdb file. In Workbench you can import them using two 'External model' and combine them in single analysis system. From the analysis you can write the APDL input file.nn
