Forum Moderator
I'll leave Arrayto comment on the moving mesh bits, I know what it does but am less skilled in the how. nYou are correct in your comment re the sliding mesh. However, if you set the angular velocity as a function of the force on the blade which Fluent calculates you can then use the angular velocity value as an output. Exactly the same as the moving mesh approach but in a potentially much neater manner. n
