February 5, 2021 at 3:09 am
HellonI am not sure about your first question. But I can answer your second question.nFor the rotating disk, it should be stationary relative to the moving zone.nUnder solution monitor, you will find Residuals .. here you can determine how much residuals you want to save and plot.nAlso you can enable autosave and save case and data files every certain number of time steps ... then load them when you want and start iterations.n
