February 5, 2021 at 6:59 am
Thanks Matt! I have just signed up in the customer portal and found the description of silent mode installation of License Manager. Though I am having trouble to find out documentation for OPERATING it silent mode.nAnd about the issue of running Fluent on the Ubuntu client, I have gone through the list of pre-requested libraries and installed the missing ones except the following which are not available for Ubuntu at all:nlibfreebl3; libopenssl1; libz1nWhen launching Fluent there is still a problem which now seems to be relating to MPI. I am saying this because the selection of MPI mode in the Fluent launcher is leading into different symptoms. nThe console in Fluent is giving out the following error log for choosing MPI = [ Default ] :n*********n/ansys_inc/v202/fluent/fluent20.2.0/bin/fluent -r20.2.0 2ddp -pshmem -host -alnamd64 -t2 -mpi=intel -path/ansys_inc/v202/fluent -ssh -cx ASRC-CalSer01:38509:35817nStarting /ansys_inc/v202/fluent/fluent20.2.0/lnamd64/2ddp_host/fluent.20.2.0 host -cx ASRC-CalSer01:38509:35817 (list (rpsetvar (QUOTE parallel/function) fluent 2ddp -flux -node -alnamd64 -r20.2.0 -t2 -pshmem -mpi=intel -ssh) (rpsetvar (QUOTE parallel/rhost) ) (rpsetvar (QUOTE parallel/ruser) ) (rpsetvar (QUOTE parallel/nprocs_string) 2) (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 1) (rpsetvar (QUOTE parallel/path) /ansys_inc/v202/fluent) (rpsetvar (QUOTE parallel/hostsfile) ) )n Welcome to ANSYS Fluent 2020 R2n Copyright 1987-2020 ANSYS, Inc. All Rights Reserved.n Unauthorized use, distribution or duplication is prohibited.n This product is subject to U.S. laws governing export and re-export.n For full Legal Notice, see documentation.nBuild Time: May 29 2020 10:12:32 EDT Build Id: 10176 n --------------------------------------------------------------n This is an academic version of ANSYS FLUENT. Usage of this productn license is limited to the terms and conditions specified in your ANSYSn license form, additional terms section.n --------------------------------------------------------------nHost spawning Node 0 on machine ASRC-CalSer01 (unix).n/ansys_inc/v202/fluent/fluent20.2.0/bin/fluent -r20.2.0 2ddp -flux -node -alnamd64 -t2 -pshmem -mpi=intel -ssh -mport 127.0.1.1:127.0.1.1:46845:0nStarting /ansys_inc/v202/fluent/fluent20.2.0/multiport/mpi/lnamd64/intel/bin/mpirun --rsh=ssh -f /tmp/fluent-appfile.asrc.148153 -genv FLUENT_ARCH lnamd64 -genv I_MPI_DEBUG 0 -genv I_MPI_PIN disable -genv I_MPI_ADJUST_REDUCE 2 -genv I_MPI_ADJUST_ALLREDUCE 2 -genv I_MPI_ADJUST_BCAST 1 -genv I_MPI_ADJUST_BARRIER 2 -genv I_MPI_ADJUST_ALLGATHER 2 -genv I_MPI_ADJUST_GATHER 2 -genv I_MPI_ADJUST_ALLTOALL 1 -genv I_MPI_ADJUST_SCATTER 2 -genv I_MPI_PLATFORM auto -genv PYTHONHOME /ansys_inc/v202/fluent/fluent20.2.0/../../commonfiles/CPython/3_7/linx64/Release/python -genv FLUENT_PROD_DIR /ansys_inc/v202/fluent/fluent20.2.0 -genv KMP_AFFINITY disabled -genv TMI_CONFIG /ansys_inc/v202/fluent/fluent20.2.0/multiport/mpi/lnamd64/intel/etc/tmi.conf -n 2 -host ASRC-CalSer01 /ansys_inc/v202/fluent/fluent20.2.0/lnamd64/2ddp_node/fluent_mpi.20.2.0 node -mpiw intel -pic shmem -mport 127.0.1.1:127.0.1.1:46845:0nFatal error in PMPI_Bcast: Invalid buffer pointer, error stack:nPMPI_Bcast(2667)................: MPI_Bcast(buf=0x7febf668b010, count=433024, MPI_CHAR, root=0, comm=0x84000002) failednMPIR_Bcast_impl(1804)...........: fail failednMPIR_Bcast(1832)................: fail failednI_MPIR_Bcast_intra(2056)........: Failure during collectivenMPIR_Bcast_intra(1670)..........: Failure during collectivenMPIR_Bcast_intra(1638)..........: fail failednMPIR_Bcast_knomial(2274)........: fail failednMPIC_Recv(419)..................: fail failednMPIC_Wait(270)..................: fail failednPMPIDI_CH3I_Progress(623).......: fail failednpkt_RTS_handler(317)............: fail failedndo_cts(662).....................: fail failednMPID_nem_lmt_dcp_start_recv(302): fail failedndcp_recv(165)...................: Internal MPI error! Cannot read from remote processn Two workarounds have been identified for this issue:n 1) Enable ptrace for non-root users with:n echo 0 | sudo tee /proc/sys/kernel/yama/ptrace_scopen 2) Or, use:n I_MPI_SHM_LMT=shmnSome compute-node processes or machines have crashed.nHost process lost connection while reading. Fatal error!n999999 (../../src/mpsystem.c@1221): mpt_read: failed: errno = 11n999999: mpt_read: error: read failed trying to read 4 bytes: Resource temporarily unavailablen The fluent process could not be started.nversion> n*********
