February 5, 2021 at 3:49 pm
Forum Moderator
I'm not sure how you've got an interface there given the top and bottom sections are connected too. Check the geometry to make sure the mesh looks OK and you've not duplicated cell zones. Otherwise it should be fine. nThe interface zone will create walls for when the two sides don't overlap. As the two surfaces are in the same location and same size the walls don't physically exist. n
