February 8, 2021 at 12:23 pm
Forum Moderator
nnYes, the options above will help you. For the Nodal Forces - Constrained Nodes. This option writes nodal forces for constrained nodes only. It is available for a Modal Analysis as well as Mode-Superposition (MSUP) Harmonic Response and Transient analyses that are linked to a Modal Analysis with the Expand Results From option set to the Modal Solution. This option directs Mechanical to use only the constrained nodes when calculating reaction forces and moments. The advantage is a reduced results file size.nnFor more details on the Output Controls please refer to the link below:nnnRegards,nAshish Khemkan
