February 8, 2021 at 12:32 pm
Forum Moderator
nnPlease refer to the following excerpt from the Ansys Help (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_geo_from_def.html)nScale Factor: this property scales the displacements of the initial configuration. If Scale Factor is 1.0, the full displacement value will be added to each node, 0.5, half the displacement value will be added, and so on. Negative Scale Factor values subtract the displacements and reverse the direction of deformation.nRegards,nAshish Khemkan
