February 8, 2021 at 1:23 pm
Administrator
Hi,nYes, this is doable. You should be able to solve for the temperature field in Fluent and impose this temperature field on Ansys Mechanical for structural analysis. Depending on how you are setting up your problem, you will need either one-way or two-way coupling between Ansys Fluent and Mechanical. You will need to use System Coupling' for this. Here is a video that might help you.nArrayYou don't necessarily need to have a one-to-one mapping between your Fluent and Structural meshes. System Coupling would help interpolate the obtained solution when you are attempting to transfer the solution from one solver to another. nThank you.nKarthikn
