February 8, 2021 at 5:06 pm
From the error message it says that we are applying VOLT BC on a slave node (66002), something that we can not do. So the workaround could be toskip the CP command and apply the Voltage BC on the electrodes directlynapply the Voltage only to the Master node in the constraint point set (CP), so only to node nr: 58802 (as per the error message). As the nodes are coupled to the master node, they will also get this voltage. So use D,58802,volt,voltage on the master node only.n
