February 8, 2021 at 8:24 pm
Hello,nPlease make sure that the battery will reach to steady state (the voltage no longer changes) in the relaxation period. You just need to leave a very small rest period if LM method is used while you do not need to include the rest period if JH method is used. However, be careful if the steady state can not be reached in your test data. You will need to either use better test data or crop the tail of relaxation time to avoid discrepancy at the bump.nThe charging and discharging data are actually imported separately. There is an option for it. You will need to prepare two sets of HPPC data, one for either charging or discharging, and input them via the option on.nThe SOC level is designated at the rest period before the pulse.nThe time should start at 0s in each HPPC file.nThank you.n
n
