maksay
Dear Yasser,nThank you for your answer,nAbout the problem you are talking about, normally the boundary condition should not change through iterations much I think as it is basically how the flow field is calculated based on. So if time step is not enough or convergence is not enough, the solution may be wrong, but still the boundary condition should be kept as it is I think.n
