MickMack
Thank you for your response, i have now successfully recorded the API as shown in the snippet belownnI am unsure of the best way to automate this procedure, as you can see i have inserted 96 end releases using the Object generator, but this is very labour intensive and my models are only getting bigger.nWhat is the best way to achieve the automation?nThe model is generated by duplicating the first module to create the other 29 modules. Can i set this up in spaceclaim some way to make the process more efficient?nThanks.n
