February 9, 2021 at 5:21 pm
Hello, nAre you using a Coupled PT solver? nDo you solve the UDS and the flow variables simultaneously? If the UDS properties are not tightly coupled to the flow, then can you converge the flow field first, then freeze the flow and solve for the UDS?nWhat discretization schemes are you using?.Regards,nSuryan
