YasserSelima
One solution is to use VOF two phase model and fill the vessel partially with water and the rest with air. nThe more smart solution is to increase the static head as a function of the outflow. You can use UDF for this.nIn both cases, you will measure the moment on the impeller and by knowing the rotational speed, you can measure the power.n
