Chris Quan
DesignModeler also has Mid-Surface tool to convert a solid body into a surface body. nOnce surface body is created, no mesh is needed through thickness. Mesh is only created in the plan of the surface body. Shell elements will be used for the surface body.nThe minimum element size could be seen when Mesh Metric is changed to Characteristic Element Length.n
