1shan
,nI am not 100% sure either since I have never used CPT212, but I just read https://books.google.co.in/books?id=7tSNDwAAQBAJ&pg=PA101&lpg=PA101&dq=fluid+flow+CPT+212+ansys&source=bl&ots=WVxqEDuwnn&sig=ACfU3U37nVVfbaCDnefZ41vrKup1_qIBtA&hl=en&sa=X&ved=2ahUKEwittbDNzP_uAhUGWCsKHSRbAOUQ6AEwCHoECAYQAw#v=onepage&q=fluid%20flow%20CPT%20212%20ansys&f=false. It looks like the only 2 unknowns that are solved are pressure and solid displacements. Flux is pressure gradient time permeability, so I believe what you get in output is the flow flux.nRegards,nIshan.n
