Keyur Kanade
First see practically you choose your domain where you know inlet conditions. nYou can use other conditions at outlet as well. nVelocity inlet and pressure outlet are most robust conditions. The inlet pressure and outlet velocity and mass flow rate etc are result of simulation. nPlease go through theory guide on how different schemes are used. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
