DrAmine
Backflow might be issue if not physical. If numerical it should disappear as you move to pseudo steady state. So you have two different cell zones and in each you have a different fluid: please check that. Also ensure that you are doing a proper initialization. Where are you seeing the backflow in the water leg or PCM leg? Which outlet boundary is used there? n
