abd fs
Dear researchers, thank you for your quick responses.nThe purpose of adding a fluidic actuator is to change the turbulent boundary layer. For more information about my work, I have divided my work plan into three stages.nfirstly I did a detailed study on the fluid actuator where I used a Based -density solver tool with ideal gas as the oscillator offers high velocity of 130m / s and an oscillation frequency of 298 Hz The results are in good agreement with the experimental results.nSecond, I am simulating turbulent flow in a wind tunnel using a Based-pressure solver with air as a liquid, and the results agree well with the experimental experience.nNow I want to unify the geometric shapes with each other as shown above.n1- Should I use the ideal air or gas?n2- Should I use a pressure-based converter or a density based converter?n
