Karthik R
Administrator
Hello,nThe greater the RPM, the more agitated the flow becomes, and this enhances mixing. Therefore, I'd expect the flow to change with RPM. Because the flow is different, the distribution of the mass fraction would also be different. nI'd suggest that you compare the flow parameters (velocity and turbulence) at this cut plane and check this. nKarthikn
