1shan
,nWhat is the objective of your analysis? Bearing connections are generally used for rotor-dynamics. If you want to perform a muti-body dynamics analysis, and see deformations of components of the assembly you could use a revolute joint and cylindrical joints(allow axial movement) for fixed and floating bearings resp. You could scope them to the surfaces where bearing touches the housing and shaft.nRegards,nIshan.n
