abd fs
Dear Rob,nthe simulation of a turbulent flow in a wind tunnel at a velocity of 20m / s equivalent to 72km / h, is similar to a simulation around a flow around a vehicle so the flow is incompressible. However, the problem arises when adding the actuator which is supplied by a pressure of 0.3 MPa and a Mach number equal to 0.45 at its output.nBest Regads,nSERRARn
