1shan
,nThere may be multiple reasons for this error message. Please check the solution information and tell us what kind of warnings and error messages you see. Also, I would suggest you replace the damper with the standard spring element in ANSYS and make sure that all the joint and connection are correctly defined by doing a rigid body dynamics analysis first(make all bodies rigid) and then move to transient. nRegards,nIshan.n
