John Doyle
Is this an Additive Manufacturing (AM) Simulation? If so, what exactly is being cut off, the supports or the baseplate or both? I am not sure, but assuming this is an AM simulation, what if you change to orientation of the build? If you stand the blade straight up to minimize its footprint (relative to the baseplate),perhaps you will not need as much support material and the cutoff will be easier to manage.n
