nPlease explain why you added a 2 mm offset to the contact.nThere are four Static Structural models. Which one should I look at?nThe paper you provided used Shell elements, which are 2D. You have used Pipe elements which are 1D. Do not use Pipe elements. Use Shell elements.n
