ramgopisetti
How about you type expression say for all Parameters . For all 100 parameters you can just type P01 in the expression field , it automatically copy the respective values into all parameters, so you left with one parameter to tune there after. nThat Said, you can use OPTISLANG Optimisation tool to bulk select the parameters and use the expression and it will applu to all selected parameters as follows nCheers,nRamn
