YasserSelima
That is why we do iterations. The first guess of velocity/pressure could be away from the solution. Ideally, the solver gets closer to the solution after every iteration. nThe relation between the moment and iterations would tell you the solution converge and reach constant value at the end of the time step before moving to the next stepn
