nAt the start of the simulation, is there a gap between the braid and the surface of the tube? If so, that is why the contact is near open. As the braid pulls inward due to the ring moving along Z and as the tube expands due to internal pressure, the contact will close.nIf there is no gap at the start of the simulation, that is when you use an offset.n
