ArraynThere are many uses for a remote point. Below is one example.nA remote point is a point in space where some of the structure existed, but rather than use lots of nodes and elements to mesh the structure all the way out to that point, the structure is cut off. A remote point is then scoped to the cut faces, while forces or displacements can be applied to the same point in space where the structure used to be.nSearch this site for Remote Force and Remote Displacement. These use Remote Points without manually creating them. That is done under-the-hood.nIf you want to apply both a Remote Force and a Remote Displacement at the same point to the same set of faces on the mesh, then you create a Remote Point and scope each one to the Remote Point instead of selecting the same set of faces twice.n
