nIf you are in Workbench and double click on Mesh that will open Mechanical, which is where you create the mesh. If there are many bodies, it might have automatically created contacts under the Connections folder. Delete them.n If you have used the Share button, there might not be any Connections folder. In that case, you're all set.n
