Rameez_ul_Haq
,assume I am conducting a geoemtric non-linear analysis. The solution is converging if I use two substeps i.e. 0.5 sec and 1 sec. Then I conduct the same analysis using 10 substeps, i.e. o.1 sec, 0.2 sec, ......., 1 sec, and it is converging for this one as well. Should I expect a difference in the results between these two? Will the latter one be more accurate?n
