Keyur Kanade
Can you please upload some images. nCan you that parameter in parameter window in WB? Can you change DP to current DP and run?nPlease search forum and you will find many posts on parameters like following. nCan you please upload some images. nCan you that parameter in parameter window in WB? Can you change DP to current DP and run?nPlease search forum and you will find many posts on parameters like following. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
